MrGreedy
Hiya,
As titled, does anyone have any opinions on which between the saloon and estate is least likely to suffer rainwater leaks?
A bit more detail/background for the interested:
As part of my search for an E320, I went to look at an 09 plate W211 this weekend (saloon).
110k miles. Heated seats. Later ntg 2.5 Comand.
Price was good at £3,850, but a few niggles and problems. Possibly the worst of which was the amount of humidity in the car.
It was frosty, and there was a lot of ice on the INSIDE of the windscreen.
The boot had a mouldy carpet/tray, but no obvious signs of water in the actual wheel well near the battery.
I'm wondering if I should focus on the least likely to leak car as my car of choice in my search. I'm also thinking if I come across a very damp interior, it's a 'walk away' job.
Trawling the internet and forums, I've discovered the following common culprits on the 211 E Class:
- Leaks from windscreen, replaced windscreen (especially if water is found in ceiling light).
- The sealing boot rubber due to age or damage, and also due to crud building up between the rubber and the metal lip it pushed on to (crud acts as a wick for water, so remove, clean and refit).
- Poor alignment of the saloon boot lid, which should be inspected from inside the boot with torch or watering can test, and boot adjusted.
- Leaves and debris in the front drains/scuttle panels, so remove, clean and refit.
- poor seal on tail-lights, and third brake light on estate, so remove/replace/clean/seal with clear silicon.
- Poor seal or rust around number place fixings.
Opinions appreciated.
