any know common faults on these? when i select it from the dash computer only the near side mirror dips when reverse is engaged, but it dips to the wrong place and then stays there when i drive forward?
I recently acquired a W211 E270 - 2005 Reg. I have not discovered this trick of dipping wing mirrors when reverse gear is engaged. Is this facility an upgrade or standard feature?
Only available if you have memory seats - and there will probably be an item in the cluster settings to turn it on/off if you have memory seats
R
The dipping mirror coding is available without the memory function.
Good point, should have said thats the factory only fit the appropriate physical mirror (with the position feedback device) in cars with memory - but it can be retrofitted.
Have never looked how you set the dip position though - I think some cars need the memory switch pack for that
R
