Not sure if it helps much, but this is what WIS says on the subject. Its for a 220 but the principles are much the same
PM me if you want a "proper" .PDF with pics with your email addy!
AR82.10-P-4632N Removing and installing xenon headlamp control module 29.4.99 Removing and installing xenon headlamp control module 29.4.99
MODEL 215, 220 with CODE (612b) Xenon headlamp unit
Illustrated on model 215
1 Screws
2 Mount
E1n1 Xenon headlamp control module
E2n1 Xenon headlamp control module
P82.10-2426-06 Removing, installing
Danger! Contact with components under high voltage
can pose lethal hazard
Do not touch parts under high voltage. Persons
with electronic implants
(e.g. pacemakers) should not perform work on
ignition system.
AS15.10-Z-0001-01A
a
Danger!
1
Danger! High voltage from xenon headlamps
Removing and installing headlamp unit
(e.g. pacemakers) should never work on xenon
headlamps.
Model 215
Model 220
AS82.10-Z-0001-01A
AR82.10-P-4730N
AR82.10-P-4730MA
2 Unscrew screws (1) and remove mount (2)
3 Disconnect xenon headlamp control module
(E1n1, E2n1) from headlamp
4 Install in the reverse order
5 Check for proper function
Copyright DaimlerChrysler AG 17.03.2009 CD-Ausgabe G/09/05 . This WIS print-out will not be recorded by Modification services. Page 1
