W211 Xenon n/s low beam
saff
Lancashire
Audi A8 D4 4.2 TDI W246 B180 CDI Sport
Hi
Just noticed the nearside low beam is out on my w211 e220 cdi. The offside is fine.
Should I just buy a replacement bulb or is there likely to be something else wrong here?
Can anyone tell me what type of bulb is required? It is an HID Xenon I think.
Any help appreciated cheers.
Hi
You will need a D2S 35 watt bulb. When one of mine went 2 years ago it also took out the ballast, or did the ballast take out the bulb? I don't know.
So I just bought a pair of cheap bulbs off of Ebay for about a tenner with a view to just using them for fault finding. But because changing a bulb is such a pain, needing double jointed hands, the cheap bulb is still fitted and working fine.
The replacement used ballast came off of Ebay, new ones are very expensive, although I have bought a cheap standby new one off of Ali Baba.
When fitting the bulb do not touch the lens and do not deviate from the standard heat range which I think is 4300k.
Many members on here will advocate fitting expensive bulbs and fitting them in pairs....pays your money etc etc etc. Mine work fine.
Steve
