W212 2012 command SD CARD Question
Erry
Yorkshire
W212 250 AMG Line
Hi all
Simply- would a 128gb card work in my command system for playing
Music files?
I have found that a 32gb micro SD works fine using a SD card sized adapter
What I want to know (before investing in a larger sized card is whether it will work above 32gb
My iPod has about 120gb of music on it, but only a few of the files show up.
Thanks in advance, I know this has been covered before, but I've read all the threads I can find and none I can find have the answer.
Erry
chrisdean
Liverpool
W205 C200 AMG Line Premium
It'll work if you split it into 4x30gb partitions and then look amongst COMAND options to select active partition.
OP
OP
E
Erry
Yorkshire
W212 250 AMG Line
Thanks mate... That's really helpful
I rang Mercedes also and they said it should work!
Cheers again!
