W212 Audio 50 - bluetooth audio streaming?
derektrotter
MB
Hi All
I have a 2011 W212 with Audio 50 and digital media interface, any idea where the bluetooth music streaming options would be?
The phone is paired and the handsfree calling side of it works fine but cannot see any bluetooth music streaming options.
I've done some research and apparently if its not visible it may need to be enabled via an engineering menu..
I'm afraid not, didn't want to mess around trying to enable it in engineering menu if it was going to mess anything else up, I've just purchased a cheap used iPod touch and going to keep that permanently plugged in instead and just update that once in a while, was just surprised Bluetooth is not in this car as its not that old.
This seems to suggest Bluetooth audio should work: http://www.mercedes-benz-mobile.com/gb/en/w212:2011-07:2012-05/details/?78768
Hi All
Not supported with Audio-50 of that vintage. It is on comand with the latest firmware applied.
If you have the digital media interface then all you need is this;
https://www.commandonline.co.uk/viseeo-wma3000a.html
