W212 E Class FUEL FLAP Won't Close
55NF
GB
BMW / Golf GTD MK8
Fuel flap won't close. The button depresses inside as if it's working, but the flap will not close. Any ideas?
This info is based on an estate but I'm guessing they're the same.
Does the button 'click' and stay in when pressed?
Druk said:
This info is based on an estate but I'm guessing they're the same. Does the button 'click' and stay in when pressed?
Yes it does
Hello. Experienced this on my saloon W212 when I first had it. Straighten out the plastic tie fitted to the cap so it's not twisted. I found that by dangling the fuel cap until it was straight, replacing the fuel cap, then pushing the plastic tie up so it doesn't obstruct the closing of the closing of the fuel flap, made the flap close each time. It's just a knack I found for myself.
Hope this helps and perhaps you've resolved since the post.
