Great thanks very much, great stuff.Which front discs did you buy?
Good luck. Do a write up afterwards.
I'll be doing mine next year.
This may help if you've not seen the WIS for this.
I haven't bought the discs yet. Thinking Brembo but open to suggestions.
Do you have a link please as I can't seem to find these on the Autodoc app?I would also get pins and springs for the pads. Its a tenner per axle from Autodoc.
I bought brembo discs (not the floating ones granted) pads & sensors from Autodoc £500 all in.
I'm sure I read somewhere that you *should* replace the caliper bolts after removal is it the same for the E63? I've ordered new ones for my C63 for when I change my discs & pads. £30 for the 8 bolts from MB.
Mine are currently one piece so it will be a like for like swap. I've not had any issues with the discs currently fitted.Did you have any issues using one piece discs? Eg warping, judder etc?
Cheers
Do you have a link to the ones you have fitted by any chance? Cheers.Mine are currently one piece so it will be a like for like swap. I've not had any issues with the discs currently fitted.
