hi again,
S212 E250 2010
I have intermittent esp inoperative. I want to disconnect the esp module wiring block to clean the pins in case it helps.
All relevant detail about the procedure is in the attached pdf below: Is there another way of separating the wiring without having to procure the special over-priced tool and without causing damage?
thanks for listening,
D.
I am seriously thinking of using a hammer...
[Codes from my icarsoft merc ii are as follows:
474C00 no CAN message received from control unit 'control unit' motor electronics dtc stored
630700 there is an internal fault in 'control unit' motor electronics dtc stored
6A4000 there is a fault in control unit 'N10/1 (front sam control unit with fuse and relay module)
Dtc stored]
S212 E250 2010
D.
Dtc stored]
