Its time for my first oil change of my e220cdi 2013, facelift. with 170k km(105k miles) on the clock. is the 229.51 5w30 the right oil for my car? Also what ATF should I use, its a 7g+.
The ATF change is not an easy DIY job, the car has to be exactly 43C temp to get the level right and you need the service kit from merc with the replacement filler tube etc
Good luck
Thank you. Previous owner stated that he changed it 10-15k km ago but I wanna change it my self to know that Im driving the car with the correct fluid and to remove some kicks. Do you know what is the capacity?
