W212 - Issues after changing car seats - SRS light
W212owner
Belgium
W212
Hello everyone,
So I swapped out my half leather interior to full leather on my 2010 w212 E200.
However there are 3 issues :
My main issue is the SRS light that won't go off.
I get following 2 error codes :
* 9CD1 Squib pyrofuse has malfunction or open circuit or squib passenger pelvic airbag has high resistance
* 9CCD Squib pelvic airbag driver has high resistance
3 . Driver seat heating does not work, the 3 dots turn on for maybe 30seconds first time you turn it on. Then it turns off, if I press it again it will turn off straight away.
I think the previous owner just destroyed the heating coil probably? Since the passenger seat does heat up fine.
I do still have my original seats, so my question to you is what should i do ?
Can i replace the faulty electronics from my old seats to the leather ones so solve the issues?
Or is it possible/easier to swap the leather to the old seats ?
I am 100% sure it's not an issue with the car because when I put my old seats back the SRS light went away (after deleting the errors with icarsoft)
Thank you
I have just realised my mistake
The leather seats I bought don't have pelvic airbags ! Why does Mercedes make so many variations...
So obviously the car will give errors then
Is there any way around this? Can the seats need to be coded? I have Icarsoft ver 3 but I did not see any option
Thank you
You can change air bag codings, but it may need SCN if done by xentry. By Vediamo or Monaco it can be done offline for sure.
Not possible to easily build in the pelvic airbags i suppose :p
The leather seats do seem to have a full plastic base, no cover to take off...
