Teflonso
I'm going to treat my shiny new E-Class to a dash cam, mounted up behind the mirror. I need to find an ignition switched live feed. If I can find a permament live as well (to feed a timer) that would be a major bonus.
The fuse box is in the boot, so that's no use and the only certain source I can think of so far is the 12V power socket in the centre console. But the car is a bit too well put together to be randomly ripping off trim to get access. The only other thought is if there is something up in the roof lining by the interior light controls, where there will also be wiring for the Speed & traffic Light Assist camera(s). So.................
Thanks people.
- Is there any source of power up by the interior light and if so, how do I access it? Pulling lenses to access screws, etc.?
- If not, can anyone advise which trim and how to remove, to get to the rear of the 12V centre console supply?
- If I have to go all the way to the 12V socket, is there a permanent 12V anywhere near that I can tap into for the timer?
- Is there anywhere else you can suggest to tap power from?
Thanks people.
