2015 E Class came up with the NOx Sensor Circuit Range/Performance Bank 1 Sensor 2 error (P229F). There is no degradation of power when driving it.
The NOx sensor 3 is also shows one of the reading failed but there is no error code generated for this sensor.
The car has done 60k miles and not under warranty anymore but it has full Mercedes service history. I read some posts that this is a common issue on Mercedes cars.
Questions:
1. Should i expect Mercedes to cover this repair cost since its common known issue? How much will it cost if they dont?
2. Can i still continue drive the car? Will it cause further damage?
I have booked the diagnostic with MB but need to be prepared on what i could expect. Hope someone can shed some light on this.
Questions:
