W212 NTG 4 to NTG 4.5 Retrofit
I have this capability but im afraid the agreement with Mercedes is that we can only do this where we install the parts or inspect they are genuine and installed as per Mercedes instructions. I think you will find the same with most Mercedes dealers.
Hello everyone,
I know that i m bringing back an old thread, if there s a problem i kindly ask one of the moderators to move it. I have a problem with my recently retrofitted ntg4 in my 2011 cls 250 (w218). All the coding is done, anti theft protection removed but unfortunately i have no image on display.. only a pale light visible in dark places.
Can anyone share the cable pinout or maybe a part number for the right cable?
I m using the same monitor that was used on the initial setup (audio 20 aps with cd changer), part number A212 900 50 00 and the same signal cable part number 212 440 64 32.
Any help would be highly appreciated.
Sent from my SM-G955F using Tapatalk
Hello everyone,
You need to get the proper screen and cable. NTG4 comand does not work with the old Audio-20 screen.
Thank you very much for your prompt reply, can you provide me a part number for the right screen and cable? thanks
By the way, here is the serial of the ntg4 unit : ME5500A2571155
Sorted out today . I had to change only the screen , i m using the same signal cable. If someone needs the necessary part numbers for retrofit pls ask.
Hi all... i changed my radio to a ntg 4.5 (gen 3) but is show 'Anti thef' message..
What I need inform to the local tecnical (DAS/Xentry without online services)?
My serial is ME7450E4042555, but i don't have 25 digits code and none sites sell this...
Hi folks, can anyone tell me if the display from ntg5 ( A218 900 63 08 ) is compatible with ntg4.5 - 4.7 units ? As far as i ve seen both of them have blue LVDS connection. Thank you in advance.
A new day and of course a new problem... I have tested two units on my car, a ntg 4.5 and a 4.7, none of them are receiving anything from the gps antenna and i get the following error code : 94D8 The GPS antenna has an open circuit. I m using the same aftermarket antenna that works without any problems on the ntg 4 unit. Is the gps antenna feed somehow on ntg 4.5 -4.7 units?
Sorry, child hassling me to go out, and figured i'd rather post a solution then do it a few hours later and probably forget.
That is a retrofit antenna (genuine Mercedes parts) for NTG4.5 COMAND - it is the correct thing to use for NTG4.5. Mount it above the instrument cluster under the dash-board (i.e out of sight) - it has a sticky pad on the top to fix it to the underside of the dashboard above the cluster.
When retrofitting we always retrofit the fans system too, many don't bother or even claim it is not necessary but Mercedes did not spend money on installing extra cooling fans unless they were necessary to prevent premature death of COMAND units and thus warranty claims.
Cheers
Richard
I ve already installed the aux fan and the air ducts, can you give me please some technical details of the antenna that you are talking about? Thanks.
Mercedes don't give technical specs of their parts .... so we don't have them, apart from its the correct part to use for retrofits, and we did a Audio-20 CD Changer NTG4 -> NTG4.5 COMAND MY2012 E class estate today ..
Can someone had done the retrofit please explain more how to screen works. Which connector for the pin number 6 & 12 ? and Can High & Can Low. please help thanks.
The OP has not said if initial startup was performed or not. Without that Pin codes cannot be generated. I know a map pin code was obtained but it doesnt say if this was via Russian hacker or a legitimate method. Legitimate method would require initial startup to have been done.
Have a look at this:
hello
i have g-class model 2009 i convert it to 2017
i have problems ?
do you have adapter to connect headhunt w204 with steering wheel w166 and the dashboard cluster is w463 model from 2003 to 2012 ?
you have any idea about it ?
i have a big company in jordan about cars and car care center !!
i need a help if you have guide helps me ?
Thank you
