milleplod
Can anyone direct me to the part numbers for the airlines please - the car has the basic self-levelling rear end. I've collected the other parts, but can't seem to find numbers for the airlines.
Pete
Pete
I had mine replaced on my 2011 S212 recently and the part numbers are:Can anyone direct me to the part numbers for the airlines please - the car has the basic self-levelling rear end. I've collected the other parts, but can't seem to find numbers for the airlines.
Pete
Might be faulty valves? Had my airlines replaced due to leak and bellows were ok. Car still occasionally drops at the rear (evenly) but not after every journey. So car is going in on Monday (they've had it back once already and it didn't drop, typical!) and they suspect it is due to faulty valves?? Might be something similar to your problem?Many thanks for the info/part numbers.
I still can't work out why the dropping is so relatively random - a leak is a leak, right, so I'd have expected consistent dropping! Hey ho, fingers crossed!
Pete
Could be - my friend who's going to do the job suggested replacing the valve block first just to see what happens! Is it behind the rear bumper do you know?Might be faulty valves? Had my airlines replaced due to leak and bellows were ok. Car still occasionally drops at the rear (evenly) but not after every journey. So car is going in on Monday (they've had it back once already and it didn't drop, typical!) and they suspect it is due to faulty valves?? Might be something similar to your problem?
Will do Al - I'd spotted the compressor service kits a couple of weeks ago, so might get one of those too. I'm just waiting for my friend to clear his garage before he can start on mine - he's currently got a W212 220CDi in there, it's got a wrecked engine after water ingress!Hi @milleplod
Mine does the same as yours. I’m convinced it’s not the pipes or the bellows as it very sporadic. The valve block is near the rear bumper, you can see the pipes coming from the compressor and going into it. It’s easy to remove. I’m going to investigate mine when I have time. I’ve leaked checked all the pipes and found nothing. I’ve noticed on eBay that you can buy a compressor service kit that replaces all the seals. An internal leak would make sense on mine. Might try that first then the valve block.
Keep me updated on yours if you don’t mind?
Al
