W213 rear speaker grill
glyndawn
mercedes c180
Hi i after changing a dented speaker grill in the rear door do i need to remove the door card to do this
grumpytosser
2017 s213 AMG Line Premium Plus +++
Yes you do it's easy enough
grumpytosser
you need a t30 screw driver
there are 2 screws holding on the door card
start at the bottom use a trim tool or your fingers to pop off all the clips around the door
remove the door cable pull back green sheath then unclip the hook
disconnect the 2/3 blue pluges ffrom the door module
disconnect the speaker cable
the speaker is just pressfit into some rubber mounts so just pull it out
then you will need to pick off the glue holding in the speaker cover then there are 4 clips just lether them out then it will come out
