W215 ICE new headunit questions
Discussion in 'Electronics' started by Scottswatches, Oct 8, 2018.
  1. Scottswatches
    Scottswatches New Member
    29
    May 6, 2018
    Melton Mowbray
    Car:
    2004 500CL, plus a 2016 Skoda Superb
    My 2004 CL500 is wonderful, but the ICE is dated. The sat nav is hopeless, no bluetooth, no USB to charge my android phone and no DAB. They are the four things I need more than the DVD player, tape deck and AM radio!
    I have looked at a PURE 600 bolt on system, but that doesn't fix the sat nav. And if I have that, plus a sat nav, plus a charger for my phone, I will have a wiring nightmare. So I have decided to replace the head unit with something like this
    AVH-A3100DAB - Car Multimedia Receivers
    that would give me DAB, USB out to charge my phone and then I can play music from the phone or use waze sat nav. But I do have some question, hence the plea for help.
    The aerial for the DAB mounts to the inside of the windscreen, but would the glass in the CL create a problem with this? Earthing it on the aluminium body wouldn't help I guess
    With COMAND removed, can you set the dashboard clock? Is there a workaround?
    Any advice greatly appreciated
  2. mattk1
    mattk1 Hardcore MB Enthusiast
    381
    Sep 1, 2011
    Guildford
    Car:
    SL63, C350 CDI & Ducati 1299 Panigale
    Have a chat with the guys at Command in Lightwater, Surrey, they are brilliant at this kind of problem/question. They are a Forum sponsor and have been used by myself and many other members, all of which I believe would highly recommend them.
    KR Matt
    Alfie and Scottswatches like this.
  3. Flyinspanner
    Flyinspanner Hardcore MB Enthusiast
    763
    Oct 1, 2015
    Ruislip
    Car:
    W215 CL500, W168 A-140.
    Electricity will flow through aluminium ok. The body is earthed.
    Some people have swapped out the head unit for other types - but you may need to rewire speakers and add an amp if your new unit doesn’t connect to the fibre optic system your car has.
  4. Flyinspanner
    763
    Oct 1, 2015
    Ruislip
    Car:
    You could look at GLKs thread
    Aftermarket HU considerations
    And also search renault12 as I think he did it too
    If yours is the facelift with the wider ICE screen, you can get an Xtrons unit specific to your model, brings functionality bang up to date, and to can add reverse cameras/ DAB.
    GLK and Scottswatches like this.
  5. Flyinspanner
    763
    Oct 1, 2015
    Ruislip
    Car:
  6. OP
    OP
    Scottswatches
    29
    May 6, 2018
    Melton Mowbray
    Car:
    Xtrons have confirmed they do not have a head unit compatible with the W215 at the moment, and the fibre optic wiring means it might be a PITA and very expensive to retrofit another system. In that case I will look at a PURE 600 add on system that sends DAB via the unused FM frequencies and includes bluetooth.
    Thanks for you help
  7. GLK
    GLK Hardcore MB Enthusiast
    2,483
    Sep 20, 2014
    Northampton
    Car:
    A200 Sports Coupé C169
  8. popuptoaster
    popuptoaster Hardcore MB Enthusiast
    776
    Oct 2, 2008
    Essex
    Car:
    2000 E55 AMG Estate
    I have an Xtrons TE706PL in my W210 as they didn't do a specific one for my car (to old I suspect) very happy with it. It was slightly smaller than the original COMAND 2 unit but I 3D printed a surround to fill in the gap and it looks great.
    'scuse the reflections it was really sunny the day I fitted it, I've also reprinted the surround since this pic so that gap down the side is no longer there, the sun had warped it where it was laying on the seat with stuff on it while i was fitting it.
    I had to fit a roof antenna for DAB, the windscreen one was blocked I think by the IR glass in my car.
    P.S. I can no longer set my digital dash clock, apparently can be cured with STAR but i don't know anyone with access to it so it can wait until i need a visit anyway.
    stephenmercedes and GLK like this.
  9. OP
    OP
    Scottswatches
    29
    May 6, 2018
    Melton Mowbray
    Car:
    In the end I fitted a Pure 600 DAB unit that also doubles as a bluetooth receiver. I was concerned, as the unit is just an FM transmitter (as my COMAND doesn't have a aux input), and the digital aerial fits to the inside of the windscreen glass and earths on the roof via a magnet - you can't do that with the aluminium roof. I earthed it on the steel A post (after breaking the a post cover - I didn't know to remove the SRS badge to reveal the 10mm nut). Almost all wiring is hidden nicely, the cigarette USB point has a spare socket (ideal for my phone) and to my surprise the signal hasn't dropped once so far.
    stephenmercedes likes this.
  10. stephenmercedes
    stephenmercedes Hardcore MB Enthusiast
    645
    Apr 15, 2018
    UK
    Car:
    W203 C240 (LPG conversion)
    Photo? I'll show you mine so you have to show me yours! LOL
  11. OP
    OP
    Scottswatches
    29
    May 6, 2018
    Melton Mowbray
    Car:
    [​IMG]
    Not stuck down yet, just wedged securely so I know exactly where to have it.
  12. stephenmercedes
    645
    Apr 15, 2018
    UK
    Car:
    All the best installations use a bit of tape/friction to ensure everything fits where you want! Looks like you tried to attach a photo,but it didn't quite come through?
  13. OP
    OP
    Scottswatches
    29
    May 6, 2018
    Melton Mowbray
    Car:
    Sorry, still getting used to this forum's methods with pictures. This should be it
Share This Page
