Borys
Did replaced my pse pump
Seems it keeps giving me trouble since. Central locking works at all times but soft closing keeps playing games. At the time I will have driver side working, boot and passenger door soft close will not work. I would reset the pump, all will go to normal but after few cycles I will have only passenger door working with rest dead.It keeps shutting down different locations on the car. Star will only tell me there is a leak but each time in different section on the car so that cannot be right. There is no hissing sound anywhere at all.
Only thing I've noticed yesterday evening. When I soft closed driver door delay on windows is quite extended to around 20 sec. While that operation in process I can hear pump working till all windows go up. Maybe pump thinks there is a leak as working for too long and it shuts down?
When doors shut not using soft close windows will go up immediately.
Is there a way to adjust,calibrate delay time on windows to shut quicker? Or problem lays elsewhere ?
Was given 6 months warranty on the pump so next week will try to use it but was hoping it can be rectified before any steps taken
