W215 Right Side Mirror Glass
helgi33
Crawley
500 SEC & CL600
I have a 2004 CL600 and the Right hand side mirror glass has gone all smoky..
I am looking for replacement glass but it is bit of a jungle out there .. From what I have gathered then I should have tinted spherical heated with auto dim function.
The W215 should only have the auto dim function on the driver side so i cant buy right hand side mirror glass from Left hand drive cars (excludes most of Europe and USA)
Does anybody know the right part number or source for aftermarket Right hand side mirror glass for right hand drive W215 which has the auto dim function }
All help really apreciated
Hi, I was in exactly the same position as you fairly recently. I searched everywhere for a pattern part but to no avail. You could always try your luck with an eBay used item but generally they come with no warranty etc.
In the end I decided to 'bite the bullet' and get OEM mirror from a main dealer to supply and fit one for me, not cheap @ £330 ish but worth it in the long run.
I could probably dig out the part number if you need it.
Matt :thumb:
