Bladerunner2125
- Apr 21, 2012
- S320 W220 2002
My Aircon has stopped working, did have the water problem coming into the car via the blocked drain under the windscreen carpet wet in the foot well, cleaned the blocked drain and let the water out, then noticed a few days later that Aircon was not working and the Red Aircon off light was lit all the time, was also getting a squeaky Blower fan.
Have had a look at the Aircon NR Readings using the two buttons (Cabin Filter & Rest) got an Error 1256 from the error readings?
Removed the Heater Blower to have a look at it, noticed that a bit of moisture had caused a little corrosion around the base of the shaft this was the cause of the squeak cleaned that up and oil and greased it lightly, the blower works fine now no squeaks but Aircon is not coming on no change in temperature when using the AC button also used to be able to hear the Aircon change the note of the engine when on, can't hear that anymore so thinking its just not working?
NR Readings as follows
NR.00 - +23.4 °C
NR.01 - +22.5 °C
NR.02 - +18.0 °C
NR.03 - +20.6 °C
NR.04 - +20.4 °C
NR.05 - +19.9 °C
NR.06 - +78.0 °C
NR.07 - 6.0 Bar (Engine Running Aircon light off )
NR.08 - +18.8 °C
NR.09 - -2.4K
NR.10 - 1.6V
NR.00 - +23.4 °C
NR.01 - +22.5 °C
NR.02 - +18.0 °C
NR.03 - +20.6 °C
NR.04 - +20.4 °C
NR.05 - +19.9 °C
NR.06 - +78.0 °C
NR.08 - +18.8 °C
NR.09 - -2.4K
NR.10 - 1.6V
