JammyBob
I have recently bought a W220 and it has now started with the dreaded battery drain. I have tried pulling all the fuses from the three fuse boxes as well as testing the mV on each fuse when the battery is in sleep mode and the voltage is zero as it should be.
With a multimeter inline I am getting 1.0-1.1 amps pulling constantly after about 5 minutes (tested up to 40 minutes) I'm thinking it could maybe be the alarm siren, voltage regulator or something with the alternator.
Just testing it unlocked now with fuse f58 removed for keyless go to see if that has any change. Any help would be greatly appreciated.
