If you put up your email address for a moment I can send it to you. Its the correct extract from WIS for your car so should be useful.
Cant you add an email add to your profile?
Heres the text below, but the document has pictures as well.
Remove/Install
1 Remove front seat i Move seat cushion fully upwards and into
the center position so that the rear bolt (14) on
the seat belt buckle is exposed.
AR91.10-P-1000MB
2 Open flap on stowage compartment (2)
3.1 Unclip stowage compartment (2)
3.2 Remove fire extinguisher With fire extinguisher, code 682.
4 Unscrew screws (4, 2 pieces) on left side
paneling (3)
5 Unscrew screw (see arrow) on the back of the
paneling (13) of the belt end fitting and remove
6 Unscrew screw (5) on left side paneling (3)
7 Pull off left side paneling (3) in the direction of
travel
Copyright DaimlerChrysler AG 18.12.2008 CD-Ausgabe G/09/05 . This WIS print-out will not be recorded by Modification services. Page 1
8.1 Unclip lower side paneling (11) in the direction
of travel
With driver seat multicontour backrest, code
404b and front passenger seat multicontour
backrest, code 405b.
9.1 Pull pneumatic lines off lumbar support control
valve
9.2 Disconnect connection coupling from left front
multicontour backrest switch group (S109),
right front (S108)
404b, front passenger seat, code 405b, or left
dynamic seat, incl. multicontour seat, code
433, right code 434.
10 Pull Omega clip (see arrow) off seat cushion
frame
11.1 Disconnect connection coupling from dynamic
seat switch
With left dynamic seat, incl. multicontour seat,
code 433, right, code 434.
12.1 Remove multicontour backrest control module
on front seat
AR91.25-P-1750M
13 Unscrew stowage compartment retaining frame
(12) from cushion frame
14 Unscrew bolt (14, 2 pieces) and push seat
cushion (1) forwards off seat adjuster (7)
n Bolt seat cushion to seat adjuster
p Do not remove seat cushion (1) from the
seat adjuster yet.
*BA91.10-P-1003-01H
15.1 Disconnect blue connector for fan motors (bl) With front deluxe seat, incl. heated seat and
seat ventilation, code 401a.
16.1 Disconnect coupling for heated seat cushion
(see arrow in enlarged section) from front seat
adjustment control module with memory left
(N32/1), right (N32/2)
seat ventilation, code 401a, or left and right
front heated seats, code 873.
17 Remove seat cushion (1) from seat adjuster (7)
18 Install in the reverse order
19 Function test of seat adjustment
n Front seats
Number Designation MODEL
220 as of
1.12.01
BA91.10-P-1003-01H Bolt of seat cushion to
seat adjusting device
Nm 15
Copyright
