BelfastBill
Well I'm having problems with my remote,it will only work when held against the little square sensor on the doors, if I use it on the drivers side I have to hold it tight against the little square and work it a couple of times, but on the passenger side it works from about a foot or two away from the door. Someone on here very kindly informed me that it could be the rear antenna at the top of the window which haven't had a chance to check the fuse for that or trace a fault, but is it the same fuse that works the radio?if so the radio is working fine. If anyone else on here has a cure or might know what the problem is you help will be much appreciated.
Thanks,
Bill.
Thanks,
Bill.
