I have a W220 S-class and I just noticed the rear window is not working. As I rarely use it it may have been that way for a while. I suspect it may have been damaged when the window was operated during a frost which froze the window shut. The motor is still OK, and I can hear it working so I am guessing that there must be a broken winder or connector to the window.
Has anyone taken the door apart and is the a complicated task?
Anyone else had a similar problem and what was the solution in terms of cost??
Many thanks
DB1
Many thanks
DB1
