SLK230Auto
- Aug 16, 2015
- SLK
I have a 2002 W220 320 CDi S Class that has the following annoying trait;
When parked and locked, the air suspension (notably the rear) rises over a period of time, say 8 hrs - this rise is around 3" or so. As soon as i unlock the car, the self levelling electrics activate and the car drops to its normal running level. If left unlocked it will eventually continue to rise then self lower until the air from the reservoir is exhausted. If unlocked and started then the car will remain at the correct level as the air compressor will keep the cylinder topped up.
Now then, am i correct in my diagnosis that it will be the air valve assembly at fault as this is the only component that can let air from the cylinder to the struts once the car is locked.
Any advice before i purchase a new one (air valve that is!) will be appreciated.
