W220 s320 Help needed please. Esp, abs, srs and airmatic too low
Frankiebateman
Blackpool
220 s320
Hi guys, new here but this is regrading my old man's car. He has a 220 s320 and recently had a lot of problems I'll try and make sense.
He had it in storage and had water ingress everywhere which led him to replacing the Sam's units and cleaning all components then his issues started. At first it wouldn't run but had star scan it all up and running but still had issue.
Esp light
Abs light
Srs light
Car too low stop warning.
He's replaced the parts which were showing faulty. Abs sensor rear right, steering level sensor, passanger seat occupancy sensor, battery replacment but he still can't figure why it won't work. The airmatic was working prior to Sam's replacment but now its stuck all the way down he says he can here the pump work with a tssss sound. All the steering buttons work, electric windows etcs.
If someone could point me in a direction to help him fix, it would be much appriciated.
Thanks again
Have you taken it to a good specialist and had the codes read ? That would be the best place to start .
Water ingress leading to electrical problems , alas , is the curse of these newer cars .
Appolagies it's a 2003 model it's been scanned by a specialist and keeps throwing the same codes up. We've replaces the Sam's units and also a couple of fuse units too we've had star scanner on it multiple times
It needs some proper time spent with it. This probably wont be an easy one to find. Water ingress is a strong possibility.
