Hi everyone,
I own a W221 2007 S320L CDI with 58,000 miles. It has a problem where 80% of the time when you kickdown it will feel like you hit a brick wall just before it should upshift (4000rpm). I have to lift my foot off the accelerator for it to shift up. If I keep my foot on the accelerator then it will do this violent kangaroo jerk jerk jerk and won't upshift.
This usually happens when kick down from standstill so gear change 1st-2nd. Or I could be driving in 3rd and kick down to 1st and same thing happens when it's about to shift to 2nd.
Done some searching and possible solutions may be gearbox oil and filter change or even the fuel filter? It's regularly been serviced with oil and filter changes but I don't see any record or gearbox oil or fuel filter.
But the posts I've read the 7G Tronic 722.9 issues are not matching my kick down symptoms and more to do with jerky gear change or when coming to a stop.
Anyone experienced the same symptoms? Thank you.
