W221 Adding tv tuner to car
Sky Bear
S320 L cdi
Hi all,
After some advice, apologies if it has been asked before but I failed to find anything using the search function.
I am looking at an buying a 2007 S class I have seen with rear seat entertainment. You can play dvd films in the rear two screens and the front but it does not have a tuner apparently. Is it possible to add a digital tuner to it? Did the rear seat package come without a tuner or is it just that this one has failed.
All help appreciated.
Mike
richard
Berkshire, UK
MY04 SL55, MY18 GLC63s
Rear entertainment and TV are separate options
It can be retrofitted - its painful as you have to replace the antenna pack above rear windscreen and antenna wiring which is hard work (and takes a long time with lots to dismantle) , and run video feeds to both the front and to the rear entertainment controller (and that loom is expensive). And the TV tuner part itself is about £800. so you are on quite a large amount of £££ to add TV.
Cheers
Richard
OP
OP
Sky Bear
Sky Bear
S320 L cdi
Thank you kindly for that info. I will consider it not financially worth it and decide based on no tv.
What a great place for helpful advice.
Mike
