No, the W221 is single Airmatic unit( damper + air cushion (spring)) for both front and rear.Does W221 system have aux air chambers? My C219 had small crack/leak on both rear chamber connection.
looks like it... it will be a pain to track thou has some lines go inside the car and to get to Airmatic tops at the rear you have to remove the seats!Well you seem to have changed everything on your airmatic system,so it might be a very small leak,and they are a pain to find.
Time to go see a specialist for airmatic. Pay the price and sleep peacefully.looks like it... it will be a pain to track thou has some lines go inside the car and to get to Airmatic tops at the rear you have to remove the seats!
I will checkthe airlines 1st, just to make sure that I did not miss anythingTime to go see a specialist for airmatic. Pay the price and sleep peacefully.
Did you finally get the air suspension sorted on your W221?I will checkthe airlines 1st, just to make sure that I did not miss anything
I think you are ABC rather than Air suspension buddyDid you finally get the air suspension sorted on your W221?
I have exactly the same symptoms on my CL (C216/W221 era) and am contemplating going straight for coilover replacements rather than chasing faults.
Ah - yes. Same symptoms tho. High on two shocks, low on two. No immediately obvious faults or leaks. Took it to a MB dealer who unhelpfully couldn't find a fault and left me a note saying "something must be faulty, can't diagnose what".I think you are ABC rather than Air suspension buddy
