W221 Recon Turbo
Discussion in 'Engine' started by Oteda, Sep 6, 2011.
  1. Oteda
    Oteda Active Member
    67
    Sep 3, 2011
    London
    Car:
    V221
    Hi, to cut a long story short, the W221 I have had the Turbo reconditioned from Essex Turbos (anyone used them?). They were the only place able and willing to do it. Since having the turbo re-fitted the car was still giving off a lot of white smoke, so sent to merc for a diagnostics who said needs a new turbo! And that the fuel injector is blocked, as well as the inlet manifold. They are currently going to fix the fuel injector, as essex turbos are adamant that the turbo is not leaking as they did all the tests and it is fine, that the smoke is due to the fuel injector blockage and excess oil.
    I am sincerely hoping the turbo is fine, anyone else had experience with this can offer some knowledge about recon turbos and fuel injector blockages?
  2. biturbo
    biturbo Hardcore MB Enthusiast
    605
    May 14, 2009
    Cheshire
    Car:
    S600 BiTurbo, SL60 AMG, Landcrapper Disco, Merc sprinter, E320 D6.
    what model w221?
  3. OP
    OP
    Oteda
    Oteda Active Member
    67
    Sep 3, 2011
    London
    Car:
    V221
    s350 CDI 2007..
Tags:
Share This Page
