ebenize
Hello!
I just bought the car and I was wondering if someone knows what might cause the white smoke after a cold start? Smells like unburned diesel. I have checked the parameters of the injectors but everyhting looks fine. It smokes white until it reaches 90 degrees, after that all fine no more white smoke but I have black smoke when cruising for a while and then kick down. I think the dpf has been removed but is it normal to get so much smoke when kicking it down? It is quite embarrassing to see so much smoke left in the rear mirror. I would like to go and check if the dpf removal was done properly...Any garage suggestions that might help me near Leamington Spa?
