leicschris
- Jul 10, 2014
- 2001 w220 320cdi
Hi All,
I have a W221 S320cdi, 2007 which I have not used for a couple of months, the MOT ran out over Xmas and kids Xmas was the priority.
I started it a couple of days ago to take it for its MOT and the radiator fan is running at full speed constantly.
I have googled and read the forums and haven't found a straight answer, some say the engine ecu at fault and some say the fan control unit.
I have an icarsoft mb2 and when the engine is running, the fan operation on live readings is 10%, which means fan off. When the engine is stopped this goes to 90%, and back to 10% as soon as the engine is restarted.
I have checked the voltages at the fan plug and have 12v + and - on the big wires, 12v on the switched thin wire and around 3 to 4 volts on the signal wire so taking that, and the 10% from the ecu, I am thinking the ECU seems to be working as normal.
Icarsoft also shows a P1636-4 fault "check component M4/7 suction fan discontinuity of fan signal" which I haven't found an answer when searching.
Had anyone any ideas, I don't want to change the fan unit if it's not the fault.
Chris
Chris
