janz
Hi all got a bit of a problem that started today - the engine radiator fan is turning on, full blast once the engine is turned off at the ignition and runs till the battery goes flat. As soon as you turn the ignition on the radiator fan goes off.
At the minute as a short term fix Ive pulled the fuse out (no68) to stop it running and draining the battery, any ideas as I cant take it to a garage as short on cash as just been laid off.
any help gratefully received
Apologies if this is in wrong section
