danclyon
SWMBO's B will shortly be needing new fronts. It's been running Falken ZE912's which have been a breath of fresh air compared to the cheese-like noisy Conti's that MB supplied it with - and have lasted almost twice as many miles....however, 912's are history and 914's are now the norm (and I read even more good things about them).
Got me to thinking though, looking at the way the load sits over the front tyres, even inflated to the correct pressures, there's a lot of outward pressure on the side-walls which tends to make the tyre look like it is very under-inflated.
Anyone got any views on running them on XL rated tyres with stiffer side-walls? Would it make a massive difference to the handling? (not that imho you could make it much worse!)
I've been looking at Hankook Ventus Prime 2 (come in normal and XL versions) that seem to be better on fuel economy and wet grip than the new Falkens (only slightly) but want to change all 4 to be the same tyres so it's stick with or move. Opinions welcome.....
Cheers,
Dan.
Cheers,
Dan.
