E240estate
- Aug 19, 2014
- 2003 S211 E240 Estate; 2003 W638 Vito
2002 W638 2.2 108CDI Vito.
I've just bought this van with suspected head gasket failure. Pressure tested and leak (gas) tested the system and both tests indicate HG OK.
Drove it for the first time this weekend, about 15 miles in total, up some steep hills, along a national speed limit road, gauge didn't move off 40 for ages and hit 50 once.
Lukewarm heat out of the heater the whole time, but never getting really hot.
I've proved gauge works, as I have had the van up to 80 degrees once, after about an hour of revving it up on the drive.
I'm guessing thermostat stuck open unless anyone has any different experience of this fault?
Question is, where is the thermostat located and what's involved in changing it? Guessing on the back side of the engine somewhere as I can't locate it from peering into the engine compartment.
