GazPB
Right, after jump starting the van with reverse polarity (not by me) the AA said the ECU was fried, so of it went to be repaired....It never came back (different story) so a ECU kit was purchased on eBay, fitting went well until it was realised the Speedo was different, mechanic I bought it off said this would not matter.
Anyway... Van won't start.
Diagnostic reader won't connect with the ECU. (Icarsoft)
Have checked all fuses with multimeter.
Things I have found is that there is low voltage on the fuses No. 8,9 & 10 to terminal 87and fuses No. 40 & 41 (engine fuse) all coming in at 0.25v
Battery is charged.
When inserting key, the steering lock releases and when key turns to start. Nothing.
Any help will be gratefully received.
Battery is charged.
