W639 power fold mirrors install
Mungo369
Norfolk
Vito w639
Hi all, I’ve got a 2.2cdi W639 with standard heated electric operated wing mirrors for adjustment only. I’ve fitted the new wing mirrors with the power fold function and have had a garage connect the van to the star software to try and activate them but no joy 🥲
I had fitted each door module with the correct unit so the extra two pin plug would plug in to the door module prior to trying the software attempt and a new door switch with the four buttons on for the rear windows (which I don’t have) but with what I was told had the function on that you could fold the mirrors with if you needed to when parking or something.
I’m thinking that there are wires missing from either the window switch loom to the door module or the main plug/loom coming into the door which then connects to the door module.
If any body could help me out with a pin out wiring diagram or some help info I’d appreciate it loads .
Thanks in advance
I can't say definitely but,
the function will be activated by the SAM. That will get its instruction from the dash menu, it is there that the function is enabled / disabled.
The SAM will likely have the ability, but I imagine your dash isn't programmed for the ability.
At a guess.
At a guess.
Ah I didn’t know there was a function in the dash menu, is it to turn on and off the function?
Da,
not everyone wants it. Eventually the wires break with continual in / out.
Yep I can see that being an issue, I’ll check the dash menus tomorrow for function. If it’s not there is it a case of getting it on star and turning the feature on?
Perhaps, but that's beyond my know how.
In truth I wish I could understand how to use Star for such things, I would change a few things on mine, Km for temperature, clock adjustment that no longer updates from the removed Comand, maybe fitting a V6 diff and changing the ratio.
