W639 SRS Light
HarleyW203
Lancashire
S203 C320cdi
Hi all, my dad has just picked up a W639 vito, it has a few issues which i am slowly working through to get it through its next MoT.
Chief of which is an SRS light, code reader pulls up
'9005 control module N2/11 circuit 15R: No voltage when voltage present at circuit 15'
I believe this is the airbag module?
Is this typical of a busted module or are there relays/ fuses i could check?
Any help is greatly appreciated.
Kind regards, Harley
Hi there,
f you mean the big SRS light in the middle of the dashboard, then I had this on my Vito.
I had removed my double front passenger seat unit, when giving my van a deep clean. I had unplugged the seat sensor cable to do so.
That would have been fine, however I had switched the ignition on whilst the seat was unplugged.
That SRS light lit, and would not go out. My code reader did not throw up any fault codes, but neither was there any option to re-set the SRS.
I researched extensively, but couldn't discover any way to resolve it myself.
Eventually I took my van to a Mercedes Indy', who plugged it into their computer & switched the circuit off.
Hth, & good luck with your "few issues list"
Incidentally, I'm not sure if they didn't switch off something else at the same time.: I seem to recall a seat belt reminder/warning operating before they reset my SRS. There is no seat belt warning now.!
Is there an alert on yours please (or was I imagining remembering it).??
Circuit 15 is ignition live.
I’d be checking fuses first 👍🏻👍🏻👍🏻
