found this on web,
P2364 Mercedes-Benz Possible Solution:
Vehicle Speed Sensor (VSS) Out of Self Test Range Indicates the VSS input signal is out of Self Test range. If the PCM detects a VSS input signal any time during Self Test, a DTC P1501 will be set and the test will abort. Noisy VSS input signal from Radio Frequency Interference/ Electro-Magnetic Interference (RFI/EMI) external sources such as ignition wires, charging circuit or after market equipment. Check for VSS input to be 0 mph when vehicle transmission is in Park.
Also
P2364 Mercedes-Benz Trouble Repair :
The sensors receive a 5 volt reference signal from the PCM. As pressure readings change, the sensor varies the voltage and the computer reads that to determine input. In the case of a broken wire, the sensor never sees the voltage and the computer assumes a major fault. So if you get this P2364 Mercedes-Benz code, first check to make sure you're getting a good 5 volt reference signal at the sensor
