Warning Codes for E200K. [2001 - Y reg]
thekendo
E200K
I've just got an E200K [Y reg-2001] Kompressor. I put it in for a full service after buying it and the test came back with a number of fault codes. I'd be very gratefull if anyone could tell me a bit more about these codes, the implications for the car and the likely costs of fixing the problems
The codes were given to me by Kwik Fit [another post in it's own right]
49: 02 sensor upstream of cat short to earth
54: secondary air system air mass to low
58: voltage circulating Air flap poteniometeres half comparison no ok
29: mixture adaption 1 [additive to lean. at idle]
Thanks in advance for any help that you can give me.
Kendo
shorty
ireland
Audi A4 , Ducati 999 , mr2
It may be due to oil in the wiring loom , it leeaches along the loom from the cam sensor to the ECU and causes different fauts
OP
OP
T
thekendo
E200K
hi, thanks for getting back to me. do you know how i could get this checked out it sounds pretty serious
shorty
ireland
The best way to check is to disconnect the plugs from the ECU and look for any signs of oil
