Warning Lights - Advice Please
db1
Yesterday when I started the ignition in the S500 (W220) there were 3 warnings displayed on the dash:
1. ESP - Visit Workshop
2. Airmatic Suspension (with the raising car logo) - Visit Workshop
3. BAS - Brake Assist - Visit Workshop
I was quite surprised, since i have never had any indications or symptoms.
I turned off the ignition, and then on again - nothing. No further warnings. Then drove home, tried again - no warnings.
Could this be a temporary glitch, or should I take it seriously. I am waiting to see what this morning brings...
Any advice welcomed
DB1
RichardM
Essex
2011 CLS350 CDI
Probably worth checking with the dealer so they can check the errors codes but I've had SRS System Failure come up when the car was only 6 weeks only, turned out just to be a glitch.
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
Hi DB1,
On my W202 the ASR/BAS rely on a minimum voltage (I can't remember the thresh-hold value) but if the voltage drops below this minimum the ECU automatically switches those functions off and warning lights pop up on the dash-board. If/when the voltage recovers the ECU switches functions back on again and voila car is back to normal.
This feature is covered in the manual, maybe it's the same for your W220? How's the condition of your battery?
S.
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
The stupid BAS/ASR switch has probably broken.
Does this look familiar?
prolly a £100 fix from the stealership, unless you get soaked for an s-class owner's premium charge or something :rolleyes:
OP
OP
D
db1
Steve,
It could be that the battery voltage was low. I returned from a 2.5 week trip during which the car was standing. It happened shortly after that.
I checked again this morning, and all was OK, so I will wait for it to reappear before going to the workshop...
thanks for all contributions
DB1
