Interestingly, putting the BS info on the plate does mean that they necessarily comply with the regulations and that they have been tested by the BSI, it means that the the manufacturer "ensures they are made to comply with".
Also, the standard is very clear - the material must be of retroreflective material as Flanaia has pointed out.
I would not wish to state one way or another whether the plates supplied by the company doing the group buy are to standard, but it may be worth asking for a copy of the test certificate from the organisation that have tested it. This will either be the BSI or TUV as they are, I'm given to understand, the only two organisation that have the necessary equipement to test that the standard is met.
The standards marking thing is a little weird in that you might expect the mark to be applied only for those products that have been tested to ensure that the standard is met. However, you couldn't test every product that is covered by British Standards, so an element of trust has to be used. In most cases, a responsible manufacturer will ensure that the standards are met or exceeded - in cases where this is not done BSI, Trading Standards, the Police or anyone can get the product tested and if it does not conform then the manufacturer is in deep trouble.
If there is a certificate that shows the plates have been tested and comply then all is hunky dory - but it's a case of asking the right question as simply saying that they have the mark on them does not mean that they actually comply. The legislation also says that an EU mark is acceptable as long at it meets or exceeds the BS standard, so by inference that would have to pass a BS 145 test (and so meet the standard). Interestingly this is one of the few areas in vehicle legislation that covers this explicitly (the BS standard eing the over-riding regulation) - as an example, HID (Xenon) lights are technically illegal under UK law but as there is an EU standard for fitting them to a vehicle they are allowed to be used.
