My problem is that I have zero mechanical knowledge which is where these forums come in handy. I feel like I need to tell MB what problem they should be looking for which is obviously ridiculous but seeing as they have tried and failed twice to rectify it, 3 times if you count the brake changes before I bought it!!!
They reified the problem in October , the problem has returned some five months later.
At least now you know the issue seems to be with the front discs , which is a start.
There was a chap on the other MB forum that had a similar issue with his E-class (he is not the only one) , he tried numerous things to rectify the problem - front discs / hubs / calipers / pads / bushes etc , he ended up getting rid of the car as the fault always returned after time. I skimmed a set of newish discs for him and they were warped even after minimal mileage , the fault disappeared only to return sometime later , i never got a chance to check the discs again as he got shot of the car.
Your car is still under the 12m used car warranty period and well within the 12m warranty of the discs that were fitted in October , so IMHO you have a couple of options.
1 - Start the battle with the dealers , either the supplying dealer or the one that fitted the new discs in October.
2 - Buy a set of new discs (Brembo / ATE / Pagid) from the likes of ECP and have them fitted and see if the problem disappears straight away , if it does then move on. If it doesn't then refit the original discs and - Start the battle with the dealers , either the supplying dealer or the one that fitted the new discs in October.
K
