So I’m about done with the Dam car. Washer doesn’t work. No power at pump. No power on wire front SAM going to pump. I’m aware no fuse , it’s electronic. Swapped to another front SAM unit . Same problem. New multi control stalk switch fitted. Same problem. ICARSOFT diagnostic tool say open or short to ground on power to pump. Checked for short to ground. Checked for power as stated no power coming out of SAM unit. Same on the other SAM unit. Is there a way to BYPASS it. A wire I can cut or spice into to bring a feed to the pump ? Wiring diagram for the feed to front
SAM to check inputs ???
Any help appreciated
Recently been sat for months due to EIS falling. New one fitted after it eventually arrived. Posted from U.K. to France ended up in USA . Took nearly 2 months to arrive, then snapped a stud in each of the left hand wheels. Oh and had to drill one of the bolts holding the airbag on the steering wheel as was sized , Running out of ideas that don’t involve petrol and matches
