I would be grateful for some help with a problem I have with my 1994 sl500.
I last used the car a couple of weeks ago and I then had windscreen washers. Just been out and found that I have no windscreen washers, headlamp washers and no headlight flash. I still have wipers, main beam and indicators.
I have checked connectors and fuses and I have power to these. I am not sure which relay it is, I have checked the one I think it might be and there is no power at all there.
Could someone tell me how to identify the correct relay? Is this likely to be related to the column switch or even the ignition switch?
I am definitely no auto electrician, any help or advice much appreciated.
Steve.
Steve.
