markevo
Can anyone advise how to get to the water circulation pump thats situated on the drivers side front of a E55 ? I need a part number so I can search ebay as new are £300 notes
I just ordered from these guys last week ordered on Sunday arrived by FedEx on Friday, it is cheaper to get shipped by USPS but can take 2-3 weeks. As I ordered 2 they agreed to ship FedEx
Mercedes Auxiliary Water Pump BOSCH C230 C280 C350 CL600 E55 S600 SL600 | eBay
But how do I get to it ? ano its the drivers side front but carn't see it from top side ?
Read post 6 and 9 of the thread http://www.mbclub.co.uk/forums/parts-maintenance/134346-e55-amg-ic-pump.html
I would check which pump you have first before ordering, see if it has a aluminium or plastic shroud as these have different electrical connectors. It should be the aluminium one but it depends if someone has already changed (trust me they will they don't last that long) if its the plastic one try the other guys from AVT as they have the 03 pump as an OEM.
That is the bracket part number
You should be fine but if you want to be extra carefull check the electrical connection is oval and not square, you should be able to feel it while still connected. If is has slightly curved edges and not square corners it will be a straight swap.
