Water Drainage Pipe
AndrewOl
Romsey
E350 A207
Hi, I wonder if anyone could help me with a part number. 2006 GL x164. The part I'm looking for fits to the bottom of the cabin air intake cowl under the grille in the bonnet. It drains rainwater through to the wheel arch. I can see the plastic pipe when I take the arch liner out. I think the pipe has been damaged as water is finding its way into the passenger side footwell. No sun roof so this is the only source I can think off. Air condensate drain seems fine. I can't see the part on the online epc. The part it connects onto is
164 830 05 40.
Well the reason there is no pipe listed in the epc is because there is no pipe! What I could see was the end of the spout on the bottom of the cabin air intake hopper. Stripped out the hopper and scuttle drain pipe. All ok with no cracks etc. Still getting rain water in the sump under the passenger seat (where the gateway is). No wet carpets so a bit puzzled as to where it is coming from. Not a small leak either. With all the rain this week over a litre of water was drained out of the sump. Any ideas?
