D
Deleted member 126251
Guest
We have moved into a property off the gas grid and so we use an oil fired boiler for our heating and hot water in winter.
I recently realised that the geyser also has an electric immersion heater and the switch looks well used (I assume the previous owners switched it on and off as they needed it).
I have two questions.
1) Is electricity more economical than oil to make hot water in summer (I can set the boiler for hot water only) ?
2) Where could could I wire a timer switch to control the times the immersion heater is active.
Thanks......
Thanks......
