Water in boot 07 W211
Discussion in 'Bodywork' started by mercmancdi, Sep 15, 2018.
  1. mercmancdi
    mercmancdi Hardcore MB Enthusiast
    321
    Feb 18, 2012
    Templepatrick
    Car:
    mercedes E320 cdi sport
    car has been sitting about for few mths and the boot was damp , about 3 was ago I dried it out and aired it
    And it’s been outside sitting since , but I now see water in boot , the think it’s drivers side .
    Where would you start checking , I am thinking taillight , but if anyone else has had this problem I would like to here what they found and how they resolved it.
    It’s a 2007 E 320 W211. The first of the pointy front
  2. KillerHERTZ
    KillerHERTZ Administrator Staff Member
    16,325
    May 21, 2003
    Cambridge
    Car:
    CLS63 AMG
    Check the actual seal around the lid, then the rear tail lights.
    Remove all the boot trim, if its dry on the walls, get a hose and soak the back part of the car. Then look for water inside afterwards.
    mercmancdi likes this.
  3. OP
    OP
    mercmancdi
    321
    Feb 18, 2012
    Templepatrick
    Car:
    Thanks that’s the way I will go.
  4. markjay
    markjay MB Club Veteran
    19,611
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    While it's tempting to blame the boot seal... on my Kia the boot was wet, and the water were coming in from the base of the roof antenna.
    Other possible sources are blocked water drainage ducts, or the rear window seal, or the round rubber plugs at the bottom if the boot (not car specific).
    Good luck.
  5. OP
    OP
    mercmancdi
    321
    Feb 18, 2012
    Templepatrick
    Car:
    Water track down the boot runs out at the tail light , at this point the seal was broke and I could actually
    Have pushed my finger through the gap into the boot at the bottom corner of the light.
    I have put a seal of mastic round it
    on a trial for now to check it cures it.
    markjay likes this.
  6. merc85
    merc85 MB Club Veteran
    6,758
    Apr 23, 2013
    Harwich
    Car:
    s211 e55k
    If it’s a saloon there are plastic trims each side of the scuttle, these can leak I think AMGeed on here had his replaced
  7. AMGeed
    AMGeed MB Club Veteran
    10,456
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    Yep, I bought 2 new ones with fitting clips. Can't remember exactly, but they cost less than £40.
    Have a check under the two removable plastic inserts either side and at the bottom of the rear screen. Loads of muck collects in there and the n/s one covers the GPS antenna lead that goes up to the roof. The cable passes into the boot and there is the possibility of water entry. Check by putting a container in the boot and pouring water over those areas with the clips removed. They just clip in place.
    Another suspect area are the rear light assembly seals. Remove the carpetting inside the boot that covers them and spray the lens with water, Then check if any has leaked past the lens seals.
    mercmancdi and merc85 like this.
  8. OP
    OP
    mercmancdi
    321
    Feb 18, 2012
    Templepatrick
    Car:
    Yes lots of dust at the joints at bottom of rear screen , Nerer got a chance to see how to remove but I assume you mean they are just the plastic stud type clips that hold them in.
  9. AMGeed
    10,456
    Nov 1, 2008
    Car:
    The side pieces are held in with a 2 piece plastic insert. The two along the top of the boot just swivel and unclip themselves.
    Its dark now, but I'll take a photo tomorrow, if I remember, to show how they remove.
  10. OP
    OP
    mercmancdi
    321
    Feb 18, 2012
    Templepatrick
    Car:
    Thanks they look a bit fiddly to change but maybe not as bad as it looks.
    In the meantime I have used good mastic anywhere I think might be the problem so will give it a day or so they spray to see if it has cured it.
    The bottom of the plastic down drives side was dozed and broke through.
  11. OP
    OP
    mercmancdi
    321
    Feb 18, 2012
    Templepatrick
    Car:
    Ok sealed what I thought was everything , brought car out and discovered the water is built up in the boot lid lining then it must leak
    Into the boot from here , am I right in thinking it’s leaking at breaklight on boot lid , or at chrome trim above number plate
    Or is there anywhere else the water could get into boot lid .
Share This Page
