Jokuk
- Apr 29, 2014
- Location
- Buckinghamshire
- E Class 350D 2010 (W212/207) Convertible
While investigating zero satellites causes, I removed the rear side panel and battery cover (W220) to check cables and noticed a lot of water in the battery well, around 100mm deep. I bailed it all out and dried the area. Reading other posts it could be a boot seal, light cluster seal or other causes. Any reason why I shouldn't drill a small hole in the floor to let it self drain in future, as I doubt I will find the cause ?
